2021/2022 Tahoe/Yukon Third row seats removal?
CBG1
Also does taking out the seats cause any codes to be thrown because of electronics?
StephenPT
St. Helens, OR
There might be codes, but they won't show up as a check engine light. Only when you connect a scan tool and do a full scan of all the modules will you get a warning.
I would be mindful that if you disconnect the wiring from the 3rd row power fold motors, you might cause a battery draw. GM published this article which talks about a battery draw issue because the BCM doesn't fully go to sleep if the 3rd row power fold connector is not fully seated at the switch.
G
genestoy
Arizona
As I said, I never removed anything. The third row seats are folded flat the way they come from the factory and I cut a piece of plywood to lay on top of the third row seats and the rear floor. It is about 4' square. To make the plywood perfectly flat I added a piece of 1x6 (screwed to the plywood) at the rear between the plywood and the rear floor and then covered the whole piece with thin black carpet.
06Z71TAHOE
