2021 Tahoe Z71 Rough Country says no to 2" lift
sanman28
Well I kinda said where I got the info, which was the RC Tech support. But no, I didn't know that. So I guess that Tech thinks all z71's have air lift suspension although I told him I didn't. Ok then there shouldn't be a problem installing the 2" RC lift pretty much all I wanted to know. Thx
Yup. U r gtg. No air means most all the lifts will work. Cheers! Post up pics when you are done!
R32driver
RC also claims their kit does not work on a yukon and the reason from their tech support was "they come from the factory with a different ride height" so I'm pretty sure they may be misinformed about what actually comes on these new vehicles. Have this kit on our yukon no issues
91RS
GA
The upper ball joints cannot handle being lifted any more. Search around the Silverado/Sierra forums and you'll see tons of people with broken upper ball joints. Hint: it causes a LOT of damage when the upper ball joint fails.
Spanman
Spanman
Massachusetts
What did you here or know about only the 1" leveling kit for the front end? I wonder if the stealer would void the repair warranty if a ball joint issue occurs. Hmmmm
sanman28
If tons of folks have this issue, there must be ample evidence on this site. Post a link to a thread.
91RS
GA
DWSmoot
Charleston, SC
What size lift/level was he running?
Tahoe4neutrals
