2024 Yukon Refresh Spied (warning- it’s not that exciting of an article!)
Ketzer
Not a fan of the new side glass design... although that is the current trend with all the manufacturers.
NYisles1
The Build and Price is up now for the revised '22 Silverado/Sierra on Chevy and GMC sites. You can really see detail on that new interior. It is a big leap in design. Something at least that nice is likely coming to the SUVs for '24 models.
Reddevil96
Chandler, AZ
I have a 21 Tahoe, I know the 22’s have a designated button for camera view which I would like. Fog lights would be nice. My only other dislike is not being able to access the RSE on the front screen. If it’s Parked u should be able to access rear screen. I take my kid to school and she has to have tv on so I have to back out of garage to get a signal then get out open her door load the screen pick a cartoon and go. That’s my main dislike. Other than that love the Tahoe, get lots compliments.
you can add the button from a 22 and it will work. I already did the leg work to confirm the wiring is in place and the circuit works as designed. You will have to look up a Stability Control Switch with all your RPO code, then add the RPO code UV2 to get the correct part number
Banks22
Michigan
Wow! Ok I’ll have to look into this, I’m not sure if there are any open switches, or where the switch is located on the 22’s
d_hawk
I have to credit this info to peterlawl84 on another forum. Based on his information I ordered the replacement switch panel to add the 360 degree camera button to my 2021 High Country Suburban. If time permits this weekend I will install and report back.DC2D504F-1C0B-44E3-99CD-A3D587781F4E.jpeg0FDD3516-8B4E-40DE-97DA-F189035157C4.png0FFBE299-DAA1-4B70-B385-2E14B1DE2AEE.jpeg923B6898-467F-4015-9AE5-ED4366689586.jpeg
Banks22
Michigan
d_hawk
Do u have a link to where u ordered this online? Having trouble searching that
It appears you need the same part that I used… 84786497
I googled that part number and ended up ordering online from quirkparts.com The part arrived today, about 10 working days after I placed the order. I called my local Chevy dealer and they quoted 2 weeks to get the part in and we’re about $15-20 more that the above website I used even with shipping included.
Banks22
Michigan
Awesome got it. Yea I didn’t get my door codes but reading what u put and adding x88 I figured it was the same part. I’m gona double check in morning and then order. Let me know how install goes if it’s just plug and play. May wana disconnect black battery cable before u unplug switch?
iaminfiji
