2024 Z71 mpg .. can it be this bad?
B-train
Most engines are tuned to run richer during the break-in period. This helps seat the rings and keep excess heat at bay. Once that period is over (usually buried deep in the ECM with certain criteria that needs to be met), it will then run on your normally scheduled programming.
Another thing to consider is that there are multiple mechanical systems that are ALL breaking-in at the same time. The machining of new parts is quite phenomenal, but there is always the final in-use period where everything learns to play nice together. I'd give it a couple thousand miles and then see where you're at.
As stated by others: winter fuel and shorter trips don't help either.
SavageDad
So you have a 5.3L 10 speed with 3.23 gears and semi aggressive tires with low miles. Do you race to the next stop light or drive at 80 mph, live in a cold climate, tire pressures low or high? Doesn't matter how I dive my 2011 Tahoe it always does 15 mpg all day unless on a long highway trip. Driving habits and above suggestions can make a big difference. Always use 87 octane and not premium fuel with a 5.3L. Let it break in but it won't help much ( it is what it is )
Just my $0.02 but I switched to 91 on my 5.3 because it runs a surprisingly high (11.5:1 I think it was) compression ratio.
carsenault300
carsenault300
We’re in southeast Texas, so not sure if the fuel is any different this time of year than summer … but yeah, we’ll hold off on any real judgements until after it hits 1k miles
And our Z71 has a small lift and larger than normal tires and wheels, 22” instead of the factory 20” IMG_5885.jpeg
vcode
And our Z71 has a small lift and larger than normal tires and wheels, 22” instead of the factory 20” View attachment 442806
Uhhhh yeah, that is part of you issue. The rims and tires. Don't be surprised if your hwy mileage sucks as well.
JayceeP
Yeah, I mean not sure the 22” wheels is the issue but rather the mud tires that are on it. That and a lift would have to be your culprit and would explain why your highway mileage is suffering.
vcode
I'm sure those 22's weigh more than the 20's which won't help city mileage.
joes99
