22's or 24's
shadrickjm
So Cal
I'm going to buy my wheels this week, but I'm having trouble trying to decide on what size I should go with:
I really like the way the 24's look! But with two toddlers, I don't want to deal with the rubbing issues. If I go with a 24, is it recommended that I upgrade my stock brakes?
I'm planning on going with a 2/3 sprindle drop.
If I were to go with 22's, then I would probably put a 285/45 series tire.........to fill out the gap a little more.
I don't want to buy 24's and have the rubbing issue, I know you can do a little trimming. Some people here have rubbing issues in the rear. I don't mind some minor trimming.
But then again, I don't want to get 22's and have them look too small.
Can anyone give some inout on which off-set I should go with If I run a 24? I want the least amount of rubbing as possible.
S
shadrickjm
So Cal
Do you know what back spacing I should go with? The wheels are 24x9.5, and I saw someone post to go with a +25 or higher and I'll be fine. Does that sound about right?
Thanks for the info............I don't know anything about SUV's
SLTexas
San Antonio, TX
i thought the 15 range was for the 01-06 models. For 07+ on a 24" wheel it should be +30mm offset. Or +25 or higher at least???
blueflamed03
Oklahoma
doh, you are correct, looked at wrong subforum. Thanks for the correct info. Sorry.
Shadfrmdabull
