26” snowflakes
Taco
Hello all my 2002 z71 Tahoe was just gifted some good used 26” snowflake rims and tires 305/30z/26 will these fit on my Tahoe or will I have to lift or put spacers. Mine is not lifted but it has 265/70/17 on her now and has good lift feel to her now just don’t want to have to spend alot of money to install these at this time. Thanks guys.
S33k3r
Dallas, Texas
You are going to need to perform some shenanigans to keep them from rubbing. You'd be going up 1.6" in diameter according to this tire size calculator: tiresize.com Tire Size Calculator
33s are usually doable, but even they are going to rub at full lock on stock ride height. Your new setup is 33.2". And you are likely no longer at stock ride height unless your suspension has recently been replaced. And we also don't know your new wheels' offset. That can also factor into whether they rub or not.
If you really want to run them, though, I suggest putting them on, seeing where they rub, and seeing if you can do some microsurgery on your Tahoe to keep them from rubbing. There's also the "NorCal mod" -- basically beat the front body components until they no longer rub on your wheels. There may be some YouTube videos on it, but I don't have time to search them out for you, right now.
Tylerldurden
