2speed transfer case
dlstyley
I'm looking to purchase 2015/16 tahoe/yukon with a 2 speed transfer case. It can be challenging to tell on used vehicles, short of seeing a pic of the dash with the 4wd knob. Is there some way to easily identify? Is it a standard part of a package? Would also like bucket 2nd row, but that's less critical.
Thanks
Kpwweb
I know it was on two packages:
Z71 - can be seen by emblems on outside.
Max Tow - have to look at the options on glovebox door or look for air shocks underneath. But I'm not sure air shocks would be a sure thing as I think LTZs had them as well.
Jorgez28
How could you tell if you have a 2 speed. Would there be a hi and low 4 wheel drive setting?
Ken G
On any of the new Tahoe's the only way to get the 2-speed Tcase is in either the Z71 (it is standard) or with the Max Trailer Pkg which gives you the 2-speed, Trailer brake, 3:42 ratio, and rear load leveling suspension on LS & LT's, the LTZ already has it with the MRC. But this is an old as I see now so you probably already know haha.
AZRiverRunner
That's correct for 2015+ 5.3L Tahoes. The max trailering in the 5.3L also includes the 3.42 gears. All the 6.2L RST Tahoes with 4x4 have the 2 speed transfer case.
97ext
