2WD 95 Tahoe lift help
2WD Tahoe
Alright, first i'd like to say is hi! I'm new, just joined today while looking for a good website for Chevy Tahoe's. So I have a 2wd Tahoe, and it was my mistake for not buying a 4WD Tahoe, but I'm stuck with it. anyways, I want to lift it and keeping the cost as low as possible. Reason being is because the back end of my Tahoe is lower than my front, and I hate it. It doesn't look right, so I want to lift it about 3-4 inches in the back and 2inches in the front. I've been looking on Amazon and I found some Universal 3in lift blocks with U-bolts included for 31$. I don't know if they're good, but the reviews show mostly they are and I am certain they will fit on my truck.
Here's the link for the lift blocks, maybe I should go 4 inch lift. http://www.amazon.com/Superior-13-1...9&sr=8-2-spell&keywords=universal+lift+blocjs
kcb37
Why not just fix it so it sit's the way it's supposed to with the rear higher?
Sounds to me like yours was overloaded.
Does it have a brake controller, or a heavy hitch?
2WD Tahoe
2WD Tahoe
Doesn't have a hitch on it. So it wasnt overloaded. Unless someone loaded the back of it with way too much weight.
Sent from my SCH-I535 using Tapatalk
Gzes
the drifting 2dr
Wichita tx
Chevys are lower in the back than in front. You can get blocks in the back just enlightened to level it out if you want
2WD Tahoe
2WD Tahoe
Yeah but I want to lift it that's why I want 3 inch blocks. Any of you know some good lift blocks?
Dowsewashere
Buy a rcx 2wd spindle lift. 4in front lift spindles and 3in blocks or you could buy 3/4ton leafs
Jongrreat
