2wd to 4wd
T-Bagg
The Esca-Hoe driver.
Doesn't Matter
Ok im keeping it 2wd just lifting it more with spindles and bigger blocks. The real question is, does anyone know if 2500 6 lug rotors will just slide on to my spindles with out any mods? If not, what all is required.
What's with all this 2500 stuff?
Why not just try some new drilled and slotted rotors that you know will fit your truck? Plus some stainless tell brake lines. You can even go bigger with a performance brake booster and some new calipers with more pistons. There are kits out there to swap your rear drums for discs(though I've read performance increase is negligible.)
It will probably be cheaper to look for stuff out there made for your truck instead of trying to make some Frankenstein suspension/drive train.
S
SYNASTR
The reason i say 2500 is because 2500's are two wheel drive and six lug. So the spindles would be the same as mine since it's 2wd. Plus when i googled it there was plenty people saying they swapped to 2500 6 lug rotors in the front to run bigger rims for a dropped truck. But no site said how they did it, or if it was bolt on. I figured someone on here would have done it before and would know whats involved. The only reason i want 6 lug is i bought 15 by 10's with 36 15.50 tires but they are six lug.
retorq
Kingman AZ
Were you wanting to swap to 4wd just to run 6lug rims??
---------- Post added at 05:02 PM ---------- Previous post was at 04:54 PM ----------
The 7200 Lbs GVW brake rotors for a 2500 use set3/set5 inner/outer bearings which is what the 2wd version uses. So I bet it you use the right rotors it would work ...
I looked into rear 6 lug axles only, there are a few older ones that are really close, I think they were old Blazer axles ... Good luck. :D
S
SYNASTR
Thanks retorq thats what i was needing to know bout the front. :) as for the rear i got options i just needed to know bout the front. Thanks guys, in a few weeks i should be getting my 4 inch spindles and bigger locks. so total lift should be about 9. plus
Administrator
This whole thread is starting to baffle me..... Surely I'm not alone! It's all over the place...
retorq
Kingman AZ
I think he wanted to swap to 4wd to get himself 6 lug axles so he can run 6 lug wheels. He wasn't thinking far enough outside the box.
S
SYNASTR
At first i was trying to go to 4wd. But due to complications. I'll just swap to 6 lug. And since i can do the rotors for the front. I'll either do spacer adapters for the rear or take and install a 6 lug rearend.
rabbiporkchop
Pennsylvania
Guys i have a question. Any help would be appreciated. I have as you know a 95 Yukon 4 door that is 2wd and has somewhat six inches of lift. I'm looking to make it a 4wd. I know your gonna say buy one but that's NOT AN OPTION. I can get all the parts from a 4wd truck cheap. Question is can a full front 4wd suspension from say a Tahoe bolt up to my frame and get the transfer case and cross member and drill for it. and both drive shafts from the 4wd and the rear end. Can it be done with out modifying my frame or anything major? Thanks guys Jake
The easiest thing to do is fab up some leaf spring brackets and toss a solid axle in.
kenmatthewclark
