Wunderground
- Joined
- Oct 3, 2018
- Posts
- 9
- Reaction score
- 12
Greetings!
I've been a member here for a few years, but spent most of that time scouring the threads for similar issues.
I'll try and keep this concise so that no one has to read through paragraphs to get info.
Vehicle:
- 2002 Yukon XL Denali
- 6.0L V8
- AWD
- 327,000kms (203,000mi)
Symptom:
- Binding/Knocking during sharp turns
- At steering wheel lock, the truck's front end almost seems to jump like it's skipping teeth on a gear.
- Happens in both Drive and Reverse
- Faint whining sound during slow sharp turns (almost hydraulic in sound)
Repeatable?: (i.e. can I replicate the issue on demand?)
- Yes
Conditions: (i.e. when does it happen?)
- Vehicle is at operating temperature
- My defacto standard for replicating involves a routine 75km (46mi) commute, whereby upon arrival to the destination, as soon as I pull into a standard parking lot spot, the truck exhibits binding/knocking like a knuckle is skipping.
- Same binding/knocking happens after a considerable amount of driving/parking (e.g. while running errands)
Troubleshooting: (what have I tried)
- Wheel Bearing replacement - I don't think it is related, but I needed new bearings at the same time I noticed the issue.
- Transmission shop examined Transfer Case - Issue persisted
- Dealership performed "Rear Diff Service" (all fluids changed) - Issue persisted
- New tires (while this was more of standard maintenance and not for troubleshooting... - Issue persisted
- Transmission shop (pt. 2) Recommended alignment. This almost had me convinced that it was the culprit, but... - Issue persisted
- Replaced shocks. Air ride conversion to conventional shocks. Rides better but... - Issue persisted
Notes:
The truck still pulls strong on the highway, no suspicious engine sounds. For all intents and purposes, the truck is fine except for this knocking sound.
Issue appears to be dependent on the vehicle being at operating temp.
The 75km commute is by far my standard troubleshooting after some work has been performed.
While I can do standard maintenance, I'm not a mechanic, and not familiar with any other component failure that could result in this issue. Steering? Bushings?
Any help is appreciated.
Thanks!
Vehicle:
- 6.0L V8
- AWD
Symptom:
- Yes
Notes:
Thanks!
