3/6 drop 2016 escalade. finally done!!
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Im done. Very happy with ride. Removed rear autoride and with my 6" springs sits perfect.
295 30 26
32.25 front 33 5/8 rear from ground to fenderlip
I will be adding this kit to my new site eskyowners.com/store shortly
BADRIDES
What shade tint is that on the side windows?
guy from norcal
That looks killer tony!
Did you use a panhard bar or any of the spohn upper/lower rear arms ?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
not yet the rear is different on these trucks. you can fit 11.5 wide wheels in back prob 12s gm moved the arms inwards on the lowers front. The bracket sits in and unlike the 00-14s when you do 6 inches on 26s the tires touch the lower mount these still have tons of clearance.
BADRIDES
I was looking in the thread where u added the bright lights around the license plate. Are the bulbs really that bright and worth the extra money $13 a bulb.
BADRIDES
Just curious as to how bright they are gonna be as the bulbs will be coming in from the side on my 02 model where the bulbs come down from the top on yours.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
you want to set up the correct bulb for application. If its side only you want side facing led. if its top down then you wand the end facing led.
BLS9
