Korn
- Joined
- Nov 13, 2010
- Posts
- 45
- Reaction score
- 0
I have a 98 yukon, about 3 years ago I installed a napa brand fuel pump, it worked for about 2 years. I also did the updated electrical connector that came with the napa pump. About a year ago I installed an Airtex pump and it works fine but my fuel gauge vibrates with it so I am guessing that the sending unit on it is kinda messed up, also it would lose its prime after sitting about 4 days.
Here about a week ago I decided to install an Acdelco fuel pump, I got it installed and it would only build up to about 48 pounds of fuel pressure and after about 2 minutes of on/off cranking it finally started and seemed to run fine. Then I shut it off and it lost all its prime in about 15 minutes. I then took it back and got a Bosh pump made by delphi, installed it and it only had about 30 pounds of pressure and wouldnt even come close to starting it. I took it out and went back to the parts store and got another Acdelco pump. Installed it and it wouldnt start it either, it had about 50 pounds of pressure.
So finally frustrated as hell I put the Airtex pump back in and it fired rite up and has about 56 pounds of pressure. Is this a coinsidence of a bad line of pumps or am I doing something wrong. The Airtex pump works fine its just after about 4 days it looses it prime and you have to crank it a bit to get it to fire up. Any ideas on this????????????????????
Before I forget, all 3 pumps worked, and by this I mean that I could here them working.
