3 out of the 4 pressure sensors are not been realized
matt76110
I was at Discounted tires, had all four sensors checked working, but when they tried to reset my "service tire pressure monitor system" message from the DIC, 3 out of the 4 were not reset. Can anyone help me with this situation, what should i do to correct it, at the minimal cost.
Thanks
M
matt76110
yes, they did all of what you said. the DIC only shows one sensor displaying reading, other 3 didn't.
M
matt76110
Thanks Treehan77 for your reply, here is the update: I pulled the fuse labeled 10A ECC TPM inside the fuse block on the lace side of dashboard, put it back in after a minute, believing it would reset the DIC. Sure it did, I was able to program my remote key which had not been able to lock/unlock car for a while and was not programmable; plus, I gave the sensors one more shot at Discounted tires this morning- all worked! The DIC can display all the reading from each tire and the "service ... Pressure monitor..." Message is cleared.
M
matt76110
they used the scanner to reset the sensors, as they tried yesterday. Those sensors were readable, but couldn't be reset at that time.
M
matt76110
the scanner does the function same as putting in/letting out air on each tire, resulting a honk after each sensor is reset
valentinitoronto
