37" MTRs on a 6" lift?
AquinoSteven
Key and Spacer Guru
Clinton, NJ
Could be both if the tire is big enough. I would just go with the 35. Cheaper, fits better, and less stress on everything.
CREETO
new orleans
you'll get better performanceand gas mileage running 35's over 37's... i don't think 6 inches will be enough clearance for those 37's
MOBmentality
Has a $25,000 Punch
Not sure on the brand, but aftermarket 16x8 rims. The 285's I have stick out like 1/2" from the fenderwell.
Edit: Also, from my googling it sounds like the 37" MTR measures out to a 36" true height. FYI
ok... sooooo the height on a tire is kinda a fictional number... street tires... measure proper because they dont claim a total height.. but.. offroad tires dont work this way... easy reason... a 16 inch 37.5 tire that is 10 inches wide.. WILL fit on a 12 or 14 inch rim and look s sexy... but it will NOT be a 37.5... it will be shorter....
in the same aspect a 14 inch wide 35 inch tire... on an eight inch rim can be 36.5-37... and wear like shit....
I wouldnt run a 16x8 with a 37 ANYWAY.. especially if the offset is shallow... then NO it DEF wont fit
Tonka Tahoe
Baton Rouge, LA
Im running 6" lift with 35" grapplers and they rub with the fenders trimmed. Id say your gonna need atleast a 6" lift plus leveling kit and spacers or body lift to fit 37's. Not to mention gears.
Sir-Lancelot
South Carolina
What are your rims offset? I only have keys/spacers and barely rub with 35's.
McAllister513
I'll answer you question right now!!! I have a 01 Hoe 2WD and I have a Fabtech 6" and 2" coil spring spacers and ford keys and I have 37x13.50x20 Toyo M/T!!
Cartwright
Not a SUV but it will give you an Idea of how high your need to go. I have a 7inch CST with a 3inch Body Lift and I am running a 315/75/R16. I perosnally wouldnt run any bigger of a tire on my set up. Stuffing is retarded and breaks stuff.
Some Crappy pics off my BlackBerry
Jacobamers
