37s on Budget - will this fit?
Jisnis
Currently have a 2015 Yukon XL Denali with Maxx Suspension 2.5” level kit in the front and 1” in the rear. I currently have wheels/tires that are equivalent to a 34”. I’ve done some slight fender modification and trimming to make the 34” work. I’ve been wanting to make a jump to 37s” and found a wheel package consisting of:
18x9.5 +12
37x13.5 Nitto Ridge Grapplers
My question is, would it be possible to fit this wheel and tire combo with just my level kit?
I’m not opposed to cutting more from the fender or bumper. Just wanted thoughts if rubbing with UCA or the body of the truck.
olyelr
Elk Rapids, MI
This guy did 37” bfg’s with a 4”. Although they are quite a bit shorter than the nittos.
https://www.tahoeyukonforum.com/threads/37”-bfg-k02-install-with-4”-sst-lift.132460/
J
Jisnis
Thanks. I saw his thread. Just wondering if others would have an idea given the specifics of what I’m trying to accomplish.
maxpsi
You’re definitely going to need more lift
and more fender trimming. With that offset, you’ll rub the UCAs, but that’s not the end of the world.
Tiki
37” BFGs are going to be at least an inch shorter than those nittos.
cmhorns
even 35's that wide is gonna take some work for sure!
37x13.5 will even rub on a standard 6 inch suspension lift!
That size is gonna take some money for sure!
Don't get me wrong, everything is doable, it just goes back to how much money are you willing to spend and/or how much work are you willing to do to it!
With just leveling, I would look at 33 at most and no wider than 11.5.
macking
