3rd row won't come out
Tim Quigley
Tim Quigley
Kingston NY
Okay, update. I got them out but the pushed the spring down and then came out. Not sure what else I should do with them now. Take all the screws out and clean it then grease again or
PG01
Up here to the right
Honestly dont think that the front brackets were in all the way. Spray with a silcone lubricant while they are out and wipe dry before you put them in. You can spray a little bit of white lithium grease up in there where u see the factory grease. The white grease shouldn't drip but dont go crazy with it... on the spring part use the silicone but wipe before u put them back. Make sure the seatbelts are on the outside of the seat when you put them back in the truck. Don't grease the floor. Good luck. U cant manually move anything while they are out... its a pia
Tim Quigley
Tim Quigley
Kingston NY
I greased everything I took off all the moldings with it and I still get stuck in the the Tahoe.
Tim Quigley
Tim Quigley
Kingston NY
honestly 3rd was the biggest mistake on buying a Tahoe. I'm happy with the caption seats and just saying I can only fit 4 people. Less aggravation
PG01
Ok, pull up on #1 so back of seat is down flat next lift up on #2 lever and raise seat about 6" then drop it down to about 2-3 above floor and pull on #3 handle and it should come right out... if not im sorry.... just did mine 9000 timesIMG_4842.JPGIMG_4841.JPG IMG_4843.JPG
Stairway2Kevin
KCMO
I'm resurrecting this, I have a similar problem. I can't get one of my 3rd row seats to release from the #2 latch to fold up so I can pull it out with the #3 handle. If that makes sense... Anybody have any suggestions on how I can get the #2 lever to release?
ihadtheories
