4.11s or 3.73s?
Alex_M
What kind of stall converter would be good?... It has a stock converter. I don't plan on boost, I want to make as much power as possible N/A.
Lots of companies make them, but I don't have experience with any of the big companies. I have a guy local who does all my converters for me however I want them.
Well what's the most torque you've seen out of a 5.3 N/A... I plan on making as much power N/A as possible on a 5.3.
That depends on how deep your pockets are and how far you want to go. With the mods you listed you're going to see decent gains. Texas speed has a dyno chart on their listing of that cam with 400 lb/ft at peak. That is certainly measured at the crank, and with headers and no accessories for sure. You will probably see 300 lb/ft at the ground with that combo if I had to guess.
If we're talking quarter mile times, 13s would certainly require boost. You're sitting on a low 19, high 18 second truck where you're at. Stall converter, cam, headers, a good tune, I could see you in the 17s. All this is dependent on altitude of course, and track. These are generalizations.
The biggest limiting factors you face are as follows, in order:
-Maintaining drivability, and even adding some peppiness on the street. By far the biggest issue. Addressing other issues will negatively impact this one and vice versa (except weight).
-Weight
-Cam
-Compression ratio
-Torque converter stall speed
-Heads (can address compression ratio)
Also, if you are wanting to have fun 4wd launching the thing, you may want to look into addressing the weak tie rods.
It really all comes down to what you want to do with the truck, but is sounds like you mostly want a street truck. If that's true then sure, I'd say throw a 2600 stall converter and 4.11 gears in the thing. For a street truck, that should be a pretty happy combo with cam and headers. You could also, when the cam is installed, have your heads worked over a bit. Fresh 3 angle valve job and cleaning up the ports a bit by someone who knows what they're doing. If it were me, I'd find a set of 862 heads on Facebook marketplace or similar. I'd go ahead and have that set worked over and ready to throw on, then sell your take offs. Minimize down time.
With a 22" wheel you're not going to have much sidewall for good launches, even in 4x4 so the 4.10s would be moot to my way of thinking. Same for the converter unless that camshaft kills your bottom end. But man, I've seen some 6.2 trucks just leap off the line with 4.10s and be gone in a flash!
M
Mrwick_02
Texas
I just really want honeycombs... You think 20s would be better?... I think the smallest honeycombs are 20s and those would be the stock gmc 1500 slt rims from 2014 to 2018.
They would certainly be better for traction and ride, just not as good as 17s or 18s for traction and ride. All projects have trade offs, you'll have to decide which things take priority.
Mudsport96
40.923,-89.488. Illinois
4.10s for what you say you want to do.
Idk how much highway driving you do, or if this is just a play toy weekend thing. But if you dont highway much go to 4.56s for best acceleration
Loss of top speed is not important really as NA you probably wont have the room to top it out in the 1/4 anyway. And the "Mexico street racing" you would need a decent amount of road to top out 3rd even a C/I 5.3 would have trouble pushing these barns over 130 anyway i would think.
3.73s at 6000 153mph
4.10s at 6000 140mph
4.56s at 6000 125mph
Those are in 3rd since it is 1:1 and likely the only gear you will be able to pull to redline NA so if you are worried about losing top end dont... you will by far need gearing for acceleration.
65 mph cruising rpm in 4th
3.73 1860
4.10 2050
4.56 2300rpm
All with a stock height tire.
Again you will be doubleing price as it is 4x4.
M
Mrwick_02
Texas
Yeah I get you... I'm also planning on doing the 2019/2020 brake upgrade which requires a 20" rim minimum, so I guess 20" honeycombs it is.
M
Mrwick_02
Texas
3.73 1860
4.10 2050
4.56 2300rpm
4.11/4.10s it is as I do a fair amount of highway driving... 50/50 highway and city driving.
Thank you all for the help, really appreciate it. I've decided to go with 4.11s. I'll start a thread where I'll post pics of the build over time.
I think you'll find it easier to locate 4.10s as they use a 10 tooth pinion gear and 41 tooth ring gear common with the 3.42s and 3.73s for the front and rear.
The 4.11s use a 9/37 pinion/ring gear and I don't see them much for the front differential anymore. Yukon Gear might have ring and pinions in that ratio for both ends though.
I miss 3.90s.
Elio_vega
