4/6 dropped
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
that front looks dumped!! one good thing you can cut the springs if you need more low on the top.
Modded
That Guy
Looks good!
Far from a 6" rear drop though.....
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Looks good!
yah i know not sure why here is the same spring on this truck i set up and his truck looks much higher in rear.
---------- Post added at 05:57 PM ---------- Previous post was at 05:41 PM ----------
chevy 808 what does your truck measure from ground to fenderlip and on what tire?
heres another truck i set up here. same springs also.
---------- Post added at 06:56 PM ---------- Previous post was at 05:57 PM ----------
do you think the helper bags lift up the rear ?? its on 12psi each bags right now . the rear rights grate tho
What helper bag part number are you using? I recently had a 60742 box but inside was the wrong bag was the 8 inch long one not 5
Have you aired it out fully and gone for a ride to see if lifts?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Same springs used thats why im not sure. Batch runs I do in sets of 150 which is min and they are all wound the same.
Chevy*808*
Chevy*808*
helper bags im useing is 60742.not sure if its the 5in or 8in bags
heres a pic b4 installing
Shimmy23
WA
it looks like the same ride height as the others... its just at a different angle making it look a tad higher especially because of the lighting in the photos
Chevy*808*
Chevy*808*
here the measurement for the rear from ground to fender lip
setting on stock 20s 275/55/20
HELPER BAGS 0 PSI
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
im at 33.25 with autoride on my truck. Not sure why it sits like that since others sat lower in pics also. Should be in mid to high 32 inch range on that tire.
CaliCrusin
