4/6 dropped
Chevy*808*
Chevy*808*
im at 33.25 with autoride on my truck. Not sure why it sits like that since others sat lower in pics also. Should be in mid to high 32 inch range on that tire.
Once I installed the 6in i was running 12 psi on the helper bags . Do You think the bags wasn't making the spring settle n been held ?
I'll run 0 psi for now n see if it settle more .drove the whole day wit 0 psi me and 3 other ppl the ride was pretty grate. Was stiff when i hit big dips tho
---------- Post added at 09:36 PM ---------- Previous post was at 09:28 PM ----------
Have you sold your current set
Lmk I have the 5in springs also belltech shock for the rear & new belltech shock extenders for sell
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
your not running isolators right?
Here is another truck I did
285 45 22
There are variances on the lower mounts on the axle. Some do sit higher than others. Well figure this out.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
rubber uppper and lower pads on springs. with my springs you dont need those
KMeloney
Did you measure the distance to the ground at the front and rear of your running boards? If you get the rear wheel gap exactly the same as the front, I'm betting that your truck is going to look like it's drooping in the rear. The trucks are designed to have SOME rake.
Just an FYI.
But you should certainly get your truck to sit the way you want it to.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Yeah I dont know why. Should dsit lower like pics I showed. Id cut a loop from higher side
Chevy*808*
Chevy*808*
air out the helper bags.i notice the rear seems to dropped a bit. hopeful ill drive it a few more days wit 0 psi n see if it settles
heres a pic wit the 3/5 kit
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Keep me in the loop you should be at 32.75 about with those tires.
Chevy*808*
Chevy*808*
I think I figure it out . I air out the bags n put back my 3 row n damn it went down pretty good looks way better . When I put on the 6in springs I aired the bags 10-12 psi n the 3 row was remove .
I'll wait a few more days then measured to see if I'm hitting close to 32'
CaliCrusin
