Zed 71
i really should crank the torsion bars or consider coil spacers to eliminate this altogether]
Torsion bars?
i ordered the 18 inch helo 835 with the 6 on 5.5 from the kirk's automotive in baton rouge... that's what's supposed to be on there (but maybe that's the bolt pattern and not the backspacing) they were supposed to know what they were doing (but they didn't), and i sure didn't at the time. when the $aving$ build up, i will have to get new rims and tires... again with the 5.5 inch backspacing... i should have come on to this site way before i ever started the lift, rims, and tires... i would of at least had a clue about what was going on, instead of figuring it out now. thanks gonzo for noticing the backspacing issue!
Not sure if you already did the lift, but there are no other mods you need to do. I;m not sure if you are mechanically inclined but I would definitly let the pros install your lift kit. You'll be happy with the results. I went with a 4 inch istead of a 6 becuase I thought the 6 would not fit in my gararge. anyways good luck!
Looked over your pics on cardomain. It looks really good. Just wondering why the back wheels look like they are further in than the front?
i put 2 " spacers on my rear to even the trackwidth from front to back... 84" total trackwidth (from outside of tires)
