2025 Tahoe 24" Aftermarket Wheels
tightchevelle69
Florida
Bought a 2025 Tahoe RST with 22" wheels. Looking to upgrade to 24" Wheels. The factory 24's come in a 9.5" width, the aftermarket ones come in 10". What backspacing and offset should I be looking for? The ones im looking at are 24x10 with 6.44 backspacing and +24 offset. Pic of truck and pic of the wheels im looking at attached.
Dag300c
Just got a 2025 tahoe high country im going 26x10 and ive had people recomend +15 for flush fitment and others recomend +20 to stay in just a little bit inside fenders. I dnt know what to go with but i see alot of people prefer flush fitment over inside the fenders. I Got from here till spring so i can make up my mind. Let me know if you end up getting anything
tightchevelle69
tightchevelle69
Florida
I did order some 24's with all terrain tires. They were supposed to be delivered tomorrow but still havent shipped. Hopefully they will be here in the next week or so and I can shoot you a couple pictures with the specs of the wheels. I also ordered lowering links (ours has the adaptive air suspension) to drop it down 1-2".
KMeloney
You already ordered the wheels but don't want to tell Dag the specs? That's curious... Just want to make sure that they fit first?
I hope you post pics here. Looking forward to seeing them!
tightchevelle69
tightchevelle69
Florida
I can post the specs but without pictures to go along with it I dont think it would really help.
Wheels:
Brand: Factory Reproductions
Model: FR98
Model Other: Escalade 12 Spoke Replica Wheels
Part Number: 98410316502
Wheel Finish: Gloss Black
Backspacing: 6.72
Bolt Pattern: 6x5.5
Offset: 31mm
Wheel Diameter: 24
Wheel Width: 10
Hub Bore: 78.10
Load Rating: 2200
Wheel Exposed Lugs: Yes
Wheel Material: Alloy
Wheel Structure: One Piece
Wheel Spoke Number: 6
Tires:
Brand: Venom Power
Model: Terra Hunter X/T
Inventory Number: CVPXT04
Aspect Ratio: 40
Inflated Diameter: 32.98
Inflated Width: 11.22
Load Index: 112
Section Width: 285
Service Description: 112H
Sidewall: Black Side Wall
Speed Index: H
Temperature: B
Tire Rim Diameter: 24
Tire Type: Hybrid AT/MT
Tire Type2: All Terrain
Traction: A
Tread Wear: 500
UTQG: 500AB
Weight: 44.16 lbs
iamrayth
