4l60e oonly has reverse
nathanreed
Just swapped motor and partially rebuilt transmission and will only drive in reverse
ccapehartusarmyINF.(ret)
Gilbert AZ
if it works in manual 2 or 3 like he said the sprag is broken
if reverse only works no matter what you do then The reaction carrier assembly (rear 4 pinion planetary) is cracked and the splines in the center are gone where the sun gear locks in to it. either way you gotta pull it apart again
N
nathanreed
I've pulled valve body to look at check balls. They're all good. Solenoids maybe?
---------- Post added at 05:09 PM ---------- Previous post was at 05:07 PM ----------
Everything internal is brand new
N
nathanreed
Yes. Shifter is moving properly. Even moved it into 1st by hand and still get no engagement. Motor sounds like it wants to stall
sfcadams
