4WD not working but no Service 4wd light
D
Dusty_GMT800
Long Island
Praying it's not a blown up tcase since that's expensive, Hopefully it's an actuator, just have to wait for the weather to get better before I can get a look underneath and see what's up.
Does it take a certain amount of time to throw a service 4wd light? It only happened yesterday so maybe that's the case?
rockola1971
Indiana (formerly IL)
It would be an instant service 4wd on the cluster. If the chain is gone then its not that expensive if you can pull the transfer case yourself and the gears arent bad. There are youtube vids that show it all. Its easy. I totally rebuilt my wifes Tahoe transfer case after she shucked the chain through the case body. I bought a rebuildable Tcase core and went at it. New bearings, seals, clutches, Pump Fix spacer and chain. Less than $300 for parts.
Austin, a Tech2 would be a good friend to have right now. If you're going to keep this truck it's an essential tool; more important than a wrench or ratchet even.
rockola1971
Tech 2 Would not prove/disapprove a internal fault to the Tcase. It could be used to activate the front axles but simply jacking up off the ground as I mentioned above would be a quick and dirty. The ****** clone Tech 2 is nice to have though! Best $250 Ive ever spent.
D
Dusty_GMT800
Long Island
You got the core and parts for $300? How hard was it to rebuild everything? Any special tools required
I'm planning on it, going to save up for the Tech2 and hopefully have one in a month or so.
rockola1971
Only "special" tools needed are a internal snap ring pliers and a bearing/bushing driver (but this can be substituted with a socket, pipe, etc.) I searched for a core on car-parts.com. They are all over the place or you can get a used unit too. Rebuilt units are on ebay all the time.
D
Dusty_GMT800
Long Island
it should be, but you will want to look at it, there is a silver dollar sized stamped plate on the transfer case (rear) showing the model and other numbers you will need
What should those numbers be? Or how would I interpret them?
I am not sure but if you were looking for a replacement the parts supplier will usually need those numbers to be sure you get the right unit, you could always google for more information
middle will say np246 then there is 2 other numbers under it and maybe one above it, I haven't looked at one in a while but I think that's all there is on it.
Thatmario956
