4x4 problems
I go every where
omaha
So I checked it out today. I pulled the actuator out and engaged it outside of the diff and it slowly popped out less than a centimeter at a time and with very little force(I could hold it back with my finger if I tried). Upon inspection I found that I was considerably low on diff fluid and I began to wonder if maybe that actuator is lubricated by the diff fluid and maybe wasn't getting any fluid because it sits clear at the top of the diff? I flushed the diff with fresh fluid and filled to the correct level and now when I press 4hi the light no longer blinks, just stays lit :party36: cant really think of an easy way to test it other than just take it wheeling. Ill let you guys know how it goes
etreanor
