I was just going to point out that if you were doing 4 pairs of 2 ohm comps on a 4ch, it would have to be wired at 4 ohms per channel, yielding you minumum power from the amp.
Hell you might want to go active right now and go with raw drivers and not a bunch of comp sets since you could easily have the capability to do so with the PXA-H100.
You could also look into pro audio drivers if you're wanting that screaming front stage.
I have suggestion for an amp then. The Crescendo Audio 3k. Will do a little over 4k at half ohm. Price includes shipping. Quality is right there with sundown...
http://www.crescendoaudio.com/product.php?productid=17515
There speaker amp is also beautiful quality. It would be exactly what you're looking for in a speaker amp.
Two awesome amps right there. I will run the 3k when I pick up a bigger car and 2nd *** 18.
Kevin
---------- Post added at 05:42 PM ---------- Previous post was at 05:21 PM ----------
And I'll add that you are buying straight from the manufacture. Comes with a 2 year transferable warranty. It is warrantied at half ohm. Not even sundown warranties their stuff at half ohm...
