5.3 or 6.0?
LaRosasAutomotive
Hello what is the biggest engine that i can put in my 2007 chevy Tahoe 4x4. I have a 5.3 flex fuel with AFM deactivation as a feature. i was thinking ????? But not sure.... that it would work with the 2007 computer.. need some help
i was thinking maybe..........L99 6.2L Gen Iv 376ci Engine 400 Hp
Part Number: 19244102
Other Names: Engine
Description: Nearly identical in performance and construction to the Camaro's manual transmission LS3 engine, the L99 engine (equipped in automatic transmission Camaro's) is 400hp with 410ft. lbs. of torque and is equipped with GM's fuel saving Active fuel management (AFM) technology. The L99 crate engine comes fully dressed with the 2010 Camaro oil pan, manifold assembly (including injectors, fuel rails and electronically controlled throttle), ignition coils, exhaust manifolds, balancer, water pump and 14. price 7 k
LS engines share the same exterior dimensions for the most part. That L99 uses the same computer as your Gen IV truck engine. Only the programming will be different. I would look for an L9H which offers slightly more power for about half the cost and lacks AFM.
