PNWMuseumman
Bow Ties Are Cool
I come to the most knowledgeable place on the interwebs (as far as I'm concerned)... I am gearing up to do some engine fixing / freshening on the 5.3 in my 02 Hoe with 275,000 miles on it. I'm wondering what else you guys think I can / should address while I have it torn apart. Here is my main goal:
Fix my extremely poor oil pressure → Barely registers on the guage when idling at operating temp. gets up to 20-30ish PSI while driving → back to not quite zero at stop lights. I am also suffering from multiple oil leaks. I suspect one of my leaks is higher up on the engine, because when the engine is hot and I'm stopped at a light, you get a faint smell of burning oil, like it is leaking out up above and burning off on the hot block. The exhaust looks alright though, don't see any blue-ish smoke to suspect engine is burning oil. Here is my plan so far.
What else can you think to address / look at / change while I'm in there?
Oil sending unit maybe? My dad had to change out the knock sensors maybe 5,000 miles ago, he replaced both of them and did the upper intake gasket, so that should be ok.
MY hope is to get this baby running good (She already runs really well, it's just the oil pressure making me nervous) and then do a BB Tune. I don't see Seattle on the schedule anytime soon, so I have a feeling I'll be doing the mail order recording and tuning... Not enough patience to wait and maybe see if they come back to Portland / Seattle.
- Change pick-up tube O-ring
- Change oil pan gasket
- New Oil pump just for good measure
- Replace valve cover gaskets (hopefully to fix upper leak)
- Spark Plugs and Wires (Just because it hasn't been done in a while) Any recommendations?
- I want to throw on an Airraid MIT while I am putting everything back together as well.
