5.3 Slipway while driving
S33k3r
Dallas, Texas
ok, i will explore this trail. I will watch some youtube videos to see how to replace my intake gaskets
I'd further suggest you research testing this theory so you aren't just throwing parts -- and your time!!! -- at an unknown problem. I just suggested the gaskets based off one of the answers you had already received. I *so* understand these problems that you just want GONE.
rockola1971
Indiana (formerly IL)
Just spray some starter fluid around intake gasket while engine is running. If the idle jumps all of a sudden while you are spraying starter fluid it means there is a leak at the intake manifold gasket and that leak just sucked in unmetered fuel (starter fluid) which caused the idle to jump up.
Fless
Super Moderator
Elev 5,280
You can use a variety of sprays: carb cleaner, etc. Propane also should work.
Spacido
Spacido
Saint Cyr les Colons - France
Hello,
First of all, I haven't tried the spray yet.
My tahoe had a very unstable engine idle and I had two codes:
P0171 mixture too lean bank 1
P0300 Random/Multiple cylinder misfire detected
the second code, I didn't have it before
Joe03z71hoe
