Our06hoe
- Joined
- Aug 23, 2016
- Posts
- 16
- Reaction score
- 6
Ive searched and havent had any luck. Thinking about doing a 6.2 swap. Has anyone done this? Is it worth it?
I went from a 4.8 to a 6.0, totally worth it Imo. Just make sure you get it tuned correctly.
If you drive it like a sane person, the trans should be fine. I blew my trans in like 2-3 months! Mine is also cammed with long tubes and converter.Ill be adding a slightly bigger cam as well. Will the stock 5.3 trans hold up to the extra hp/tq?
No.Ill be adding a slightly bigger cam as well. Will the stock 5.3 trans hold up to the extra hp/tq?
... if there's AFM and VVT on the engine that would have to be deleted...
