5 inch drop riding height
bsims3996
bsims3996
alabama
Well, with 24s, that would bring you 1 inch higher off the ground then my 22s. (which it does) I'm at 33 inches and your at 34 inches....thats how it should be..both of us running 5 inch drop coils. Your new springs are fine. It seems as if your old springs were more then 3 inch...maybe a mistake in packing from the factory...iono. But your sitting where you should be right now on 5 inch drops.
What is your fender height up front btw?
the front is at 33 inches with keys
i'm going to put the old ones back on since it's only a 1/2 inch and the old ones rides 1000 times better. the rougher ride would be justified by the 2 more inches i thought i was going to get but not a 1/2
BlizzardX23
Sacramento, California
hmmmm...I just measured my front, Im running 30 5/16 from 2 inch drop spindles and torsion keys (100% cranked UP..still more to go for lower stance)
lowAZhoe
Resident GM Tech
Phoenix, AZ
im at 33" up front and about 34-34.5" in the rear on a mcgaughys 3/5 on 24's with 295/35/24
BlizzardX23
Yea....see...yours dropped as far as mine then if your at 34 and Im at 33....your front is just adjusted higher then mine though...You used 2 inch drop spindles right? and new keys?
lowAZhoe
Resident GM Tech
Phoenix, AZ
yea 2" spindles and keys. actually one key is stock and one is mcgaughys..did that so that one of the bolts isnt hanging out all the way..
SPIS
