5" rear drop question
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
The djm rear kit comes with
5 inch springs
shock extenders
trailing arm brackets
swaybar brackets
you can just get the rear spring if needed also.
BlizzardX23
Sacramento, California
I wish there was a money back guarantee from these companies. DJM vs. McGaughys
Give a full price safety deposit for the springs, and try them out..if they dont settle as low as your prior springs (the competitors springs)..you get your money back...if they DO settle lower then the other springs, the company keeps your full price deposit
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
djms drop it 5 inches and 5.5 on a suburban
R
red02chevy
Lubbock
What is the price on the DJM 5" rear springs? Also, did you guys ever figure out if any of those springs from Summit would net a 6" rear drop. I am going to have to get the rear down to match the front and to make that happen it might need a 6" rear drop.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
8-500 for the big drop you will need to weld the spring onto the lower perch which is just spot welding it in a few places and its done.
R
red02chevy
Lubbock
How is the ride with those springs? If they are a little soft or stiff I can revalve my Fox shocks to help the ride. This is my chicks whip so I have to make it ride pretty good so I don't have to listen to her *****. Also can I run the McGaughys helper bags with those springs?
Thanks for all the help
ANHannie
