Replacing both motor mounts on an 04 Tahoe that I'm swapping in a 6.0 lq9. Rockauto is showing different GM part #'s for motor mounts for an '05 Cadillac Escalade vs. the '04 Chevy Tahoe. 15226255(Pink) or 25828247 (Red)...not sure what the color mention is about?
Are there differences and what are they between these two GM part #'s for motor mounts that I would've thought to be the same? Same Gen 3 based engine and same GMT800 chassis.
Dovetail on this question, are 07+ GMT900 motor mounts same/interchangeable/useable on 00-06 GMT800 vehicle?
Need to source a set of motor mounts this week to keep the swap moving forward. 5.3 is just about in long block form in the engine bay, pulled intake-front accessories-wire harness, and going to attempt slipping the long block out of the bay with wire harness tied up, A/C compressor pushed aside, Alt/Power Steering pushed aside, and water pump removed.
