PNWMuseumman
Bow Ties Are Cool
I cannot figure out what could be causing this / how to fix it. The idle lop is pretty bad when the engine is hot and running the AC. I had the alternator die a year ago and changed it out, so I know it's good. Also changed the battery then. My only other thought is to change the battery cables because the negative has quite a bit of battery acid build up on it. But I'm not sure if that would contribute to this.
I know the video doesn't look like it is very bad, but it is SUPER annoying anytime it's hot outside. and It's usually worse thatn shown here.
Thoughts?
Thoughts?
