6.0L Swap
1995mudrunner
Does anyone have any experiance or know where i can find info about droppin a 6.0L chev into a 95 tahoe
rich5368
Cheyenne, WY
As long as you have the harness with the motor it should be a pretty straight drop. Can't be too different from all the Honda swaps I used to do on Integras and Civics. Might have to do some custom motor mount work but other than that it should slide right in.
1995mudrunner
i was more wondering about transfer case and tranny, driveshafts and no offence but i wanted someone that has more experieance with the 6.0l and the 5.7l's but thank you
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
try ls1 tech.
or try the subforum with the BODY/enginebay you are using, rather than the donor engine forum.
ie the 91-99 forum.
abbygore
