Can anyone tell me the scope of work to replace the oil pump on my 6.2 liter?
i am aware it is located on the front of the motor behind the crank pulley.
what i am unaware of is if one needs to do any of the following:
remove timing chain cover
remove cross member
remover oil pan
remove front differential/drive terrain components
I am hopeing to do it this weekend if i dont have to tear everything in the front end apart.
if anyone has done this job or has the knowledge and will share it, that would be very help full!!!
also, do you have any suggetions on the high flow(volume) unit that can produce 33% more through the pump. I have a pretty stock motor just looking for longevity.
thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
on a sub note if your looking for the detail on why i am replacing it, here is the list.
-28 F in Minnesota resulted in no oil pressure.
replaced filter and pressur sensor(clogged filter/frozen condensation).
resulted in oil pressure at operating specs.
on an 8 hour drive directly after, halp way through oil pressure dropped to 10 PSI at 2200 RPM, after passing Semi at 4400 RPM(not sure of PSI)
let motor sit for 10 minutes and received 28PSI at idle again.
I concluded that i either have shit in the oil pan and is getting sucked up by the sump, or my bypass valve on the oil pump is Sticking when i drop the hammer and get over 4000RPM(Which should be 40PSI oil pressure).
remove cross member
remover oil pan
