6.5" speakers in door.....will 6.75" Kenwoods fit?
Yukon Ron
Texas
Found some 6 3/4" Kenwood three ways for the rear doors that are 6.5" and I wanted to know if anybody knows if they will still fit....
any help would be awesome
01TX_Tahoe
Semper Fi
Pasadena, TX
If your talking about the rear doors on a Tahoe/Yukon, then not without some heavy mods. You're going to have to measure the mid for clearance and more than likely make some sort of pod for it to fit or an adapter. But as they say, anything is possible.
Yukon Ron
Yukon Ron
Texas
Thanks man, I ended up getting some 6.5"s. It wasn't worth the savings to have to modify anything. Thanks again.
jdpber
GOLD MEMBER
The America
some 6.5 baskets will drop right into the 5 1/4 slots.. and others need mods.. depends on the speaker model and brand.. larger basket larger drivers need mods..
groundscr8pr
flaccid member
scarborough maine
correct.. not all manus use the same standard for speaker frame size. some will call a 6" a 6.5 when a true 6.5 is much larger.
stormtrooper777
