$79 bucks for an AFM disabler = drive better AND better gas mileage?
TahoeFL2017
I went the cheaper route and got the AFM disabler on amazon (not a tune, just plug and play)
Wish I had done it sooner, truck stopped hunting for the right gears/RPM , and my highway mileage went up (?)
This mod plus using E85 has got me enjoying this truck all over again :)
89Suburban
Bull in the china shop
SE PA
Good move buddy.
SpyShops212
Doesn’t the tune do other things that the odb devices don’t? I would recommend changing the vlom with the updated one as well and maybe the lifters. At the very least the vlom.
Marky Dissod
Permanent V4 disablement is one of the very many things that may (or may not) be included in a proper ecm tune.
(I say 'may not' because years ago, instead of disabling V4 mode, I went the other way and
INCREASED the V4 mode duty cycle on a 2012 Yukon XL. IT WAS A BIG MISTAKE.)
If more people better understood what an ecm tune can do, every single one of those people would've already gotten an ecm AND a tcm tune
(because they'd also better understand what a tcm tune can do).
Shutting off V4 mode:
gives V4 mode lifters much better odds of surviving much longer (for best results replace V4 mode lifters with V8 mode lifters and replace VLOM)
extends the life of the torque converter clutch, which tends to be the chief culprit behind most transmission rebuilds.
captras
Sugar Land, TX
I have done alot of research on the AFM disablers. They do work, but not the way they lead you to believe. They actually do not disable the AFM. What they do is prevent the transmission from going into the highest gear, which is the only gear that the AFM can be activated in. You can do this on your own by simply putting your shifter in M5 (for 6 speed) or M7 (for 8 speed). This is what a tech from Range Technology told me when I asked what the device actually did.
RST Dana
OH
I don’t have one, and I’m not from Missouri, but somebody would have to show me before I’d believe it prevents the transmission from going into high gear.
petethepug
Michael
SoCal
Someone with a AutoSync module could confirm that the trans never goes into the last gear as well as the overdrive. All they’d have to do is flip the display on the DIC to show what gear the truck is traveling in at highway speeds.
Rygrego
Mission Viejo, California
Totally not true. I've had a Range disabler for 3 years and my truck is using all 6 gears. On cruise I can average around 23-24 MPG with no V4.
MrMonte
I tuned out AFM 30K miles ago and my Avg mpg went from 20.1 to 20.3. Pure hwy is mid 20s with a 6.2L/10 speed.
Ibustbravo
Centennial, Co
As soon as I have enough time here on the forum to post, I'm selling my range device. looks brand new.
My engine still blew up. I think in stock form theses engines have a 'grenade timer' and it can't be reset until you pull the AFM kit out of the engine.
jack004
