'92 dash lights will not come on.
Gzes
the drifting 2dr
Wichita tx
Did tou check the gray wire? Its on the same geound where the obd connector is
M
MSborn882007
Turns out it must be a short since its popping the fuse. Tried to pull the dash to find the short but after I pulled it an seeing how much Pita it was gonna be with the wiring connected to the dash to pull it all the way out I gave up
Gzes
the drifting 2dr
Wichita tx
It shouldnt be hard just run a new wire and keeo the old one but cut where yoy dont need it because of the new wire. Trust me you will love having the lights back
M
MSborn882007
problem solved.i took the cluster all the way out and saw that one side of the connectors on the cluster was bent down some.bent it back out and now the light works.so if anybody has this problem BE SURE to check this portion. I would have saved a lot of time and headache if I had checked this
OklahomaSideShow
