93BlkOnGreenPro's 2007 Yukon SLT Build Thread
93blkongreenpro
93blkongreenpro
That really does look great - dare I ask how much it cost?
This was his 1st interior hydro dip, so I'd rather not say what I paid, bc it seems its way too low. Others have mentioned that a complete hydro dip like I did would be in the neighborhood of $300.
93blkongreenpro
93blkongreenpro
Replaced my IM. Moroso said to twist and remove the PVC valve. Moved the ground. And amps arrived.
93blkongreenpro
93blkongreenpro
PPI 900.5 is getting replaced with the 4channel and 1 channel. Double the wattage on the DC stage 2 12 from 450 to 800ish at 2 ohms.
93blkongreenpro
93blkongreenpro
This is how the truck looks at the end of the day. Got the backup camera working finally, and got the harness situated. Now my iMastro is not working. WTF. Got my power distribution wired up to switch and I will be plugging in all the accessories to it. Then to get the PPI 900.5 upgraded to the pioneer 4 channel and 1 channel.
The PPI 900.5 and the under console w/ kicker 8" will be up for sale. It's a good oem upgrade.
93blkongreenpro
93blkongreenpro
More progress. All 3 tv's are now working again after Chevy messed with my wiring. Backup cam is functional again as well. PPI amp is out and both Pioneers are now installed and working. Front facing cam was working and now it's not. What else? I will use the Pioneer AutoEQ for the initial tune and see how it sounds.
93blkongreenpro
93blkongreenpro
Truck back together. Did the pioneer AutoEQ and it sounds off up top. I will try it again later.
I ran all my accessories off this little gem I found on eBay a few years ago. And my ground off this distribution that I found in a toolbox umteen years ago. This are the 12v switched accessories and it's ran through a relay to trigger these. I like the fact that they have all individual fuses.
bobbywdatool
