95 tahoe Blend doors
vendo
vendo
ma
yes 3 wires brown and ground have voltage i didnt check the white one..if i started it would probably be 12volts
vendo
vendo
ma
I had volt meter on brown and black and voltage changed..should i check the white and ground?
vendo
vendo
ma
i put 12v into my old one and it moves no problem..small motor.
east302
Mississippi
Yes, check both. One will be a battery and the other will be a signal and is what changes based on the dial setting. I want to say it (the signal one) ranged from 1 to 12V or maybe it was 1 to 5. Something like that, but definitely a noticeable range that you can see on the meter.
vendo
vendo
ma
so the white one and the ground for the signal and turn dial..will try that tues after work..
east302
Mississippi
Went and checked mine (1998 model). White to ground is signal and varies from 12V (face vent panel dial setting or all the way counterclockwise) to about 0.5V on full defrost. It was around 6V at the 12 o’clock dial position.
Brown to ground is battery and was always 12V or so. Doesn’t change with dial position.
vendo
vendo
ma
what do i do if there is no signal from that wire?
east302
Mississippi
It would point to an issue with the control panel or damaged wiring in between it and the actuator.
nuggettss1
