95' Yukon SLE 2 Door 4x4
Eddy
Texas Panhandle
I Need Help ,I Went Mudding And Got Stuck. All Of My Left Side Was Basically Underwater. Also My Right Rear Tire Was Bent Inwards. So I Left It Setting For A Good Hour To Go Get Help ,When I Pulled It Out My Engine Started Knockin A Little And Has A Rough Idle. It Shakes A Little When I Put It In Drive. Also My Rear Right Wheel Wobbles Now... What Should I Do???
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Remove plugs and inspect for damages. blow out any debris with compressed air and clean the rest of ignition system. It sounds like a misdirected and your cel should be flashing as a result. Change your oil afterward. Inspect on how wheel is bent. Is it because of axle damage?
E
Eddy
Texas Panhandle
I Washed All The Mud Off And Debri ,How Do I Clean My Ignition System? Yes The Wheel Was Damaged Cause Of Axis Damage. My Cel??
SunlitComet
OBS Jedi-Do Good
Cel check engine light. Make sure wires are clean and damaged remove cap an rotors blow out any water in there and make sure terminals are clean.
SunlitComet
OBS Jedi-Do Good
that is a good sign then. but you do have rough running still after cleaning? i should have mentioned you should check condition and levels of all fluids as well.
E
Eddy
Texas Panhandle
I Checked My Engine Oil And It Seems Like There's Water In It. When I Start It Up It Runs Smooth Then It Starts Shaking And The Engine Nocks Just A Bit But Moves The Truck. What's Really Concerning Me Is When I Put It In Dive It Shakes Bad And Sounds Like It's Doing To Die On Me.
Donnie Yukonie
Yates Caretaker
DONT RUN THE VEHICLE!!!! you probally hydrolocked , STEP 1 remove spark plugs and wet air filter and dry fire your motor with plugs removed (turn the key as if your going to start it) note of course it will not start because there are no spark plugs in it this just shoots any water out of the cylinders so that you dont bend a rod (because water cannot be compressed it will bend engine parts) step 2 is leave the plugs out let dry while that happens drain oil change oil filter and replace, step 3 replace spark plugs and add a fuel additive to gas tank , check distributer for water and dry accordingly . then make sure everything is tight and secure and try starting it , water might come out of the tail pipe at this time
step 4 run vehicle to normal operating tempature moniter overheating and any abnormal conditons if any occur post problems here
and STEP 5 - DONT DO IT AGAIN lol
:hands: ive done this way to many times when i was younger, btw your alty might fail prematurly now
---------- Post added at 01:49 PM ---------- Previous post was at 01:47 PM ----------
on a side not how on earth is the axle bent? can you post pictures? im thinking the rim is bent , check and make sure all the lug nuts are TIGHT
E
Eddy
Texas Panhandle
Alrite Don. ,, The Thing Was Is I Was Stuck In A Ditch And I Was Backing Up To Get Out And When I Went To Get Out My Back Wheel Got Stuck But Was Way Bent Inward I'll Post Some Pics Soon And It Doesnt Seems Like The Axle Is Bent But The Wheel Does.
Donnie Yukonie
Yates Caretaker
yea , for your axle to be bent you must have been givin her hell , but ive bent a rim before . follow those steps above and let us knw what happens
bdewitt205
