95' Yukon SLE 2 Door 4x4
E
Eddy
Texas Panhandle
Alrite Well I Changed The Oil And Spark Plugs. It Runs Very Smooth Now. But Still A Slight Knock On Start Up But Goes Away When It's Hot.
purple 'hoe
Green Bay, Wisconsin
A slight knock can turn into a larger issue. Inspect for any other issues, as stated. Any pictures of the "bent" wheel. Are you sure the axle is not twisted or tweeked?
retorq
Kingman AZ
To fix the knock you have to identify the knock. If it goes away when it's warm it's most likely not a bearing ... may be piston slap.
bowtiefreak
No Quarter
Near Philly
wheel is bent? Pics will help.
Also on the motor, if this knock just started after this...Id be worried. Something is failing.
Donnie Yukonie
Yates Caretaker
yea hydrolocking motors is never fun thats y i quit doing it ...
bdewitt205
