2drhoeon4s
- Joined
- Apr 5, 2010
- Posts
- 383
- Reaction score
- 12
waited for this to happen...
148K miles. Auto trans,
floored it to merge, trans got to the top of a gear and popped. I immediately let off the gas and coasted to a stop, no smoke, no fluids, no overheating. now it shifts weird, but it still shifts, when I let off the gas at speed it seems to go into neutral, as the rpms drop to a complete idle, then when i push the gas a bit it revs for a second then finds a gear and goes. Oh and it doesnt have reverse anymore. Do you guys think I need a new trans or just a torque converter?
---------- Post added at 06:45 PM ---------- Previous post was at 06:30 PM ----------
more info... the truck never died, I coasted to a turn lane, then did a u turn and drove hom, it shifted, but they were sloppy shifts like it was searching for each gear before finding it... No overdrive. I t has 1st though. I know because I live on a super steep hill and it always kicks to 1st when I drive up it slow. I got it home and pulled in the driveway... then the other day I started it up and went to back it out of the driveway. No reverse. Free revs like neutral. nothing happens at all when I shift from park to Reverse to neutral. No noises, no clunk, no movement. I put it down in drive and i can feel it shift into gear. I let off the break and it moves forward. I give it a little throttle and it goes, back in reverse and nothing again. Not sure what it is. I have a CEL but it has been there since my headers because I deleted my cats. I dont have a scanner to check.
---------- Post added at 08:11 PM ---------- Previous post was at 06:45 PM ----------
********side note********
If I replace my trans, how difficult would it be to convert to 2WD? Can I retain my 4WD front hubs? Im sure I can get a 2WD trans, and 2WD driveshaft, and then remove all of the front diff and transfer case components and front axles.... correct? any electrical changes?
