99 GMC Yukon no heat **SOLVED
Fless
Super Moderator
Elev 5,280
The pic is a bit blurry but is that meltage (made-up word) around that pin?
GMCChevy
Senior Member
I went for a ride today and I can hear the mechanism moving in the dash when I set temp from hot to cold and back. In addition, the air was see your breath cold with the temp set to cold. I felt the upper and lower radiator hoses and the uppers warmer than the lower. There’s a coolant leak as the reservoir was empty but radiator was still pretty much full.
Did you check the rad hoses or heater hoses? Rad hoses should have a difference like that the heater hoses shouldn't be as noticeable but both should be warm.
the 18th letter
the 18th letter
Northern New Jersey
I did not since cleaning the connection on the old switch resolved the issue and got the heat hot again.
Mily
