99 tahoe clock spring
K
kene
everything works like new
horn works
airbag light blinks around 7 times, light goes out
---------- Post added at 03:28 PM ---------- Previous post was at 03:20 PM ----------
sorry to confuse you
my 1 wire in 1 wire out are green and white together 1 sheath
other had 2 sheaths in and 2 sheaths out
SunlitComet
OBS Jedi-Do Good
unknown at this time.
wwwwwhhhhhhoooooooo!!!!!!
hold the keyboard pal.
the light is supposed to do that at every start. it is indication of a test of the system. after about 7 flickers it should go out and stay out. if it stays on then you have an issue somewhere. if it does not light at start up then a fuse or bulb may be burned out.
save yourself the 150 for something that is actually broke.
K
kene
this is with the new clock spring
old clock spring light stayed on
sallimoservice
