99 Tahoe project getting started
Norton
MI
what would be the best susoension lift kit for this Tahoe? Its the old body style heard 98 Tahoe kit will work is that true?
Donnie Yukonie
Yates Caretaker
Im assuming you have autotrac so any kit for it will work. As for what kit is best that could be argued all day. Whats your budget that will help us help you?
sent from my vortec powered droid 4 using tapatalk
N
Norton
MI
1500 2500 bucks at least 6" lift yes it has auto trac. That is auto 4x4 right sorry first real build need all info i can get
Donnie Yukonie
Yates Caretaker
Yes that means you have the auto4wd selection on the 4x4 switch. Now the 2500 is this include tires as well or just lift also are you installing yourself or getting someone to install it
N
Norton
MI
that depends on how much kit is and yes installing myself have done lift before brother inlaw is a mechanic
---------- Post added at 11:37 PM ---------- Previous post was at 11:36 PM ----------
I was also told stock rims wont work with kit true
---------- Post added at 11:46 PM ---------- Previous post was at 11:37 PM ----------
Just found Pro Comp 6"-5 1/2" lift $1700 dont specifie what all come with it call tommorow when they open. Hope its got everything in it. Found other kits but they are all missing something.
Donnie Yukonie
Yates Caretaker
Dont know what kit they were reffering to but all the lifts i know about stock wheels will work, it really comes down to preference i chose super lift because it uses the old tech of lifting aka bracket style, the newer style is knuckle lift.
Bracket normally has to be welded in some places and knuckle does not also from what ive been told going back to stock is easier on knuckle lifts
---------- Post added at 11:47 PM ---------- Previous post was at 11:46 PM ----------
Also quick question for you how high are you going?
N
Norton
MI
6" so a knuckle kit would be better sorry man new to forum still trying to figure it out
Donnie Yukonie
Yates Caretaker
Dont worry man im here to help. And Well it depends who you ask which is better, its been argued to death but both types are good kits. Knuckle tends to be cheaper (at least superlift wise) some companys discontinued the bracket style because the knuckle is easier to install. My reccomendations for that price is either RCX. 6 inch kit is 1000 bucks ( not sure if new front driveshaft is included) and its a knuckle kit
Super lift is 2340 (what i paid) and the drive shaft is included. Mine was a bracket. But they also have a knuckle syle
N
Norton
MI
cool RCX Drive shaft is not with it. so far its between RCX or tough country you been lots help keep in touch will get before and after pics up when i pull it out of my barn no lights in there to take any.
N
Norton
MI
getting ready to order Tough Country 6" kit cant wait everything is starting to come together, just need to get it all and install everything
eod_tech
