99 yukon 5.7 vortec misfire HELP
ccapehartusarmyINF.(ret)
Gilbert AZ
i checked it out 95 was the last year for the flat tappet cams 96 and newer motors are all hydraulic lifters and roller cams
but like i said worse case scenario its possible with a motor with 216k miles its possible that its a bad valve spring or bent pushrod broken pushrod cup in rocker arm causing the valve to float
OR VietVet
Multnomah Falls
Military
Willamette Valley
If the engine had bad/bent/broken valve or springs or rocker the problem would be apparent right off the bat on start up.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Agreed but instead of separating out the broken possibility I just lumped it all together in my post. Broken bent will likely show asap where as weak may take a bit.
Gilbert AZ
gotcha sorry to nit pick
this brings up another interesting quesiton when is a good time to change yer valve springs how many miles are they typically good for
OR VietVet
Multnomah Falls
Military
Willamette Valley
I don't think I have ever changed them as a maintenance item unless I was having problems and then they were diagnosed as the problem or when heads are off and at the machine shop the tech tested them and said were needed.
L
Greenville, al
Ok I work at night I will try to get up early next week and go get it scanned for the history. I may go ahead and buy the Delphi mfi since it would be better in the long run.
Gilbert AZ
thats kinda what i thought but then when i was researching floating valve symptoms i came across posts by dudes on other forums claiming valve springs were only good for like 60k miles and i was like WTF thats a newone on me one post even said they needed to be changed every 30k miles
OklahomaSideShow
