99 yukon cross member
spider9
4l60 to 4l60e cross member
hello need help,
anyone swap a 4l60 to a 4l60e in a 99 yukon, tail housing cross member frame holes not lining up- i know the e had deeper converter and bell housing / do i change cross member / change mount / or drill
thanks for your help
S
spider9
hello need help,
have 99 yukon came with 4l60 / changed to 4l60e / cross member mounting holes to frame no longer line up to mount cross member under trans
do i -- change cross member -- trans mount -- or drill out holes -- or light the fuse
thanks
retorq
Kingman AZ
The 4L60 and 4L60E use the same transmount and it's in the same exact location, did you mean you changed from a 4L60e (which was standard in 99) to a 4L80e??
SunlitComet
OBS Jedi-Do Good
unknown at this time.
something is not right. first off if it came with a 4l60 someone went way beyond a repair or rebuild to get that thing to work. also it was stock with a 4l60e so there should be no issues. any more details?
S
spider9
sorry took so long to reply
99 yukon came with a 4l60 i was trying to put a 4l60e out of a 2000 tahoe in it
for know this won't happen - can make everything bolt up but the torque converter / if i try to get the flex plate to fit the converter the flex plate will not bolt to the crank so thanks for your help but looking for 4l60 now and i did get the cross member in after a little twisting and turning just to have to take it back out
thanks again
Willee
