A/C blows super slow
RAWVORTEC
Lburg
I have replaced the resistor and the fuses. Before, only my high fan would work, and even then it doesn't feel like the air is coming out. I have cleaned out everything behind glove box. No leaves/clutter. I NEED to fix this thing. Currently I ONLY HAVE HIGH FAN.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
so fan at high is fast air for you then? can you disconnect motor and measure volts on the different speeds please. and at the blower fuse under the hood as a reference please. also you output vent controls are solid? no stray air out of a vent?
RAWVORTEC
RAWVORTEC
Lburg
Fan at high is equivalent to maybe half on my wifes 2003 yukon. I'll have to get a voltometer. If I turn the fan to face, it shoots out all vents, but MOSTLY face. I'm sure the little foam outline on all of the vent doors are gone
b18cls1
