Hi guys Im new here, and a new owner of a low mileage (68,600) 2000 LT tahoe 5.3, i started to have the ABS brake light come on out of the blue and read about it online, however im at a loss here, any help would be greatly appreciated.
Things i've done/tried so far:
Cleaning of hub location rust build up etc(altough) it was clean of front abs speed sensors (no luck)
Replaced both front hubs with new sensors(no luck)
Replaced rear speed sensor(no luck)
Replaced ABS pump also with EBCM from wrecker (still not fixed)
Errors I've got : erratic speedo, trans wont shift.
Computer readings gave just one code: C0236 rear wheel speed signal circuit missing. Also live data stream showed front left & right sensor speed reading, but rear sensor stuck at 3mph while driving.
Has anyone had this error and if someone could share any tips where to go from here i'd be grateful.
